Targus Wireless Optical Mouse - Black
Quicklinx: BPYBWS00 Mfr#: AMW060EU
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
11 in stock
£11.76 ex VAT
£14.11 inc VAT
Targus Wireless Optical Mouse’s 1600 DPI sensor and compact design make it the ideal device for the office or on the go. Offering wireless freedom and built-in USB receiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation, you can move through documents and webpages quickly. Enjoy a clutter free workspace at your desk or on your coffee table with this 2.4GHz wireless mouse.
  • Compatibility
    Designed to work with PC, Mac or Netbook computers.
  • Technology
    High-Definition sensor provides up to 8 months of battery life.
  • Optical Sensor technology
    1000 DPI high-precision laser sensor technology accurately responds to mouse movements.
  • Easy storage
    Stow-N-Go USB receiver is small enough to store inside the mouse while traveling.
  • Ergonomic
    Ergonomically designed to lend hours of comfort in any size hand.
Targus Wireless Optical Laptop - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
6 cm x 9.53 cm x 3.81 cm
118 g
European Union
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1600 dpi
Scrolling wheel
Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.7 - 10.8
Mouse
Wireless Receiver
6 cm
9.53 cm
3.81 cm
118 g
European Union
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Movement Resolution
1600 dpi
Scrolling wheel
1 x USB - 5 pin Micro-USB Type B
RoHS
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Targus
Price Range Ex VAT: 0 - 50
