Targus Wireless Blue Trace Mouse - Red
Quicklinx: BBRVWS00 Mfr#: AMW5003EU
The Targus Blue Trace Wireless Mouse, features the latest Blue Trace technology for accurate and precise tracking. Blue Trace technology combines the power of optical technology with the precision of laser technology for remarkable tracking on almost any surface including wood, granite, and carpet. The ergonomic design reduces wrist strain for comfort and the mouse is ambidextrous for both left and right handed users. The Micro USB receiver can remain permanently in the USB port for instant connectivity or can be easily store inside the mouse when travelling Wireless capability eliminates clutter from the workspace while RF 2.4GHZ technology significantly reduces cordless interference and signal drops allowing the mouse to work up to 10meters away.
  • Optical sensor technology
    BlueTrace technology combines the power of optical technology with the precision of laser for remarkable tracking on almost any surface including wood, granite and carpet.
  • Dual-purpose design
    Large enough for comfortable desktop use, yet shall enough for the mobile user.
  • Ergonomic
    Ergonomic shape provides support to help prevent palm strain; designed for left and right handed users.
Targus BlueTrace - mouse - 2.4 GHz - red
Mouse
Wireless - 2.4 GHz
Red
Orientation
Right and left-handed
6 cm x 10 cm x 4 cm
140 g
Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
800 dpi
Scrolling wheel, Blue Trace Technology, wireless receiver slot
Apple MacOS X 10.4 or later, Microsoft Windows 2000/XP/Vista/7/8
2 years warranty
Mouse
Wireless Receiver
Orientation
6 cm
10 cm
4 cm
140 g
Red
Europe
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Movement Resolution
800 dpi
1 x USB - 4 pin USB Type A
