Targus Vuscape cases feature a form fitted design which holds and protects your iPad. A durable exterior for high performance protection combines with a super soft inner lining to protect your iPad screen. Vuscape cases are equipped with magnetic closure on the front cover which immediately wakes up your iPad and then shuts down after use, as well as a new integrated stylus loop which allows you to securely store your stylus. The case easily transforms into a hands free stand with a choice of different viewing and typing positions. The lightweight design makes the case easy to carry and offers access to all your iPad features and functions while still inside the case.
- Targus VuScape Protective Cover & Stand - protective cover for tablet
- Product Type
- Protective cover for tablet
- Screen Size Compatibility
- 9.7"
- 19.5 cm x 29 cm x 3 cm
- 0.55 kg
- Localisation
- Europe
- Material
- Lychee polyurethane leather
- Black
- Limited lifetime warranty
- 19.5 cm
- 29 cm
- 3 cm
- 0.55 kg
- Material
- Black
- Localisation
- Europe
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Scratch-resistant
- Closure Type
- Magnetic closure
- Inner Dimensions
- 18.57 cm x 24.12 cm x 0.88 cm
- Cover Features
- Stand function
- Lifetime
