The Targus VuScape™ Protective Cover/Stand for Samsung® Galaxy Tab™ 1 10.1" features a form-fitted design that holds the Galaxy Tab in place and conveniently converts into a stand with three different viewing angles. The lowest angle is ideal for typing directly on the screen. The VuScape Cover/Stand is ultra-thin and lightweight, making it easy to carry inside of a backpack, briefcase or bag. The case also provides full access to all functions so the Galaxy Tab is fully operational without leaving the case. The soft interior lining adds color and protects the device against scratches. When not in use, the case conveniently snaps closed like a portfolio to protect the screen. The Targus VuScape Cover/Stand combines a sturdy viewing stand with an ultra-thin design for easy travel.
- Targus VuScape Protective Cover & Stand - hard case for tablet
- Product Type
- Hard case for tablet
- Screen Size Compatibility
- 10.1"
- 26.5 cm x 1.6 cm x 18 cm
- 263 g
- Material
- Faux leather
- Black, blue
- Limited lifetime warranty
- Designed For
- Samsung Galaxy Tab 10.1, Tab 10.1 WiFi
- 26.5 cm
- 1.6 cm
- 18 cm
- 263 g
- Material
- Faux leather
- Black, blue
Carrying Case
- Hard case
- Recommended Use
- For tablet
- 10.1"
- Protection
- Scratch-resistant
- Inner Dimensions
- 25.7 cm x 0.87 cm x 17.5 cm
- Cover Features
- Stand function
- Lifetime
- Designed For
