Targus Vucomplete Back Cover for The new iPad - Black
Quicklinx: 80B3WS00 Mfr#: THD007EU
We've got you're back covered
Simple, minimal, Vucomplete adds a protective backing to your new iPad® to shield it from scratches.
If you want to protect your treasured new iPad®, but don't want to sacrifice its unique style, VuComplete™ protective back cover is just the thing. It fits snugly around the back and sides of the iPad® and can be used in conjunction with the existing Apple® Smart Cover. The high-end, weaved texturing on the exterior is wipe-able and easy-to-clean, and it also allows the Apple® logo to remain visible.
  • Apple® Smart Cover Compatibility
  • Strong, Rigid Backing
  • High-End Textured Material
  • Visible Apple® Logo
Targus Vucomplete Back - protective cover for tablet
Protective cover for tablet
Screen Size Compatibility
9.7"
21 cm x 29.5 cm x 2 cm
200 g
Europe
Material
Polyurethane
21 cm
29.5 cm
2 cm
200 g
Material
Polyurethane
Europe
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Inner Dimensions
18.82 cm x 24.35 cm x 1 cm
Lifetime
