We've got you're back covered
Simple, minimal, Vucomplete adds a protective backing to your new iPad® to shield it from scratches.
If you want to protect your treasured new iPad®, but don't want to sacrifice its unique style, VuComplete™ protective back cover is just the thing. It fits snugly around the back and sides of the iPad® and can be used in conjunction with the existing Apple® Smart Cover. The high-end, weaved texturing on the exterior is wipe-able and easy-to-clean, and it also allows the Apple® logo to remain visible.
- Apple® Smart Cover Compatibility
- Strong, Rigid Backing
- High-End Textured Material
- Visible Apple® Logo
- Targus Vucomplete Back - protective cover for tablet
- Product Type
- Protective cover for tablet
- Screen Size Compatibility
- 9.7"
- 21 cm x 29.5 cm x 2 cm
- 200 g
- Localisation
- Europe
- Material
- Polyurethane
- Black
- Limited lifetime warranty
- 21 cm
- 29.5 cm
- 2 cm
- 200 g
- Material
- Polyurethane
- Black
- Localisation
- Europe
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Inner Dimensions
- 18.82 cm x 24.35 cm x 1 cm
- Lifetime
