Targus Versavu iPad Air 2 Tablet Case - Light Grey
Quicklinx: BC1HWS00 Mfr#: THZ47102EU
For a slim iPad smart case, look no further than the Targus Versavu 360-degree iPad Air 2 case. The perfect fit cradle holds your iPad Air 2 securely, while the deep foam grooves provide angles for comfortable viewing and typing. Our 360-rotating technology allows you to seamlessly switch from landscape to portrait effortlessly. Made of a polyurethane material, the slim design keeps your device clean and protected while easily traveling with you. The discreet cord closure makes sure that your device stays in place when you’re on the move. The Versavu 360° fits conveniently in your bag, so you’ll never have to worry about your iPad weighing you down.
Targus VersaVu 360° Rotating - flip cover for tablet
Flip cover for tablet
18 cm x 2 cm x 24.6 cm
260 g
Europe
Material
Polyurethane
Grey
18 cm
2 cm
24.6 cm
260 g
Material
Polyurethane
Grey
Europe
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Scratch-resistant
Cover Type
Flip cover
Camera lens cutout, adjustable multi-angle mode, port cut-outs, 360° of rotation, buttons cutout
Cover Features
Stand function
Lifetime
