Targus VersaVu Classic Flip cover for iPad Pro 12.9" - Black
Quicklinx: DS53WS00 Mfr#: THZ651GL
Device Type: iPad Pro
Type: Cover
Device Screen Size: 12.9"
Colour: Black
Stock Status: Used Stock
£43.36 ex VAT
£52.03 inc VAT
The bestselling Targus Versavu range returns with a Multi-Gen case for the 12.9-inch iPad Pro, compatible with both the first and second generation. Featuring a smart-fit rotating tray, which offers hands free portrait and landscape viewing with access to iPad ports and camera. Sound scoops built into the case around your device speakers enhance and direct sound towards you. The front cover has a soft interior to protect the device screen and deep foam grooves to provide angles for comfortable viewing and typing. This iconic case design reveals the statement iPad Apple logo on the back of your device when in use.
Targus VersaVu Classic Case for iPad Pro (12.9-inch) 2nd gen./1st gen - flip cover for tablet
Flip cover for tablet
23.5 cm x 2.2 cm x 31.4 cm
498 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
23.5 cm
2.2 cm
31.4 cm
498 g
Lining Material
Plush fabric
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Waterproof, drop-proof
Cover Type
Flip cover
Open Type
Side
Additional Compartments
Apple Pencil
24 cm x 35.6 cm x 2.5 cm / 0.7 kg
Cover Features
Stand function, rotating
Max Height of Shock Resistance
1.22 m
Lifetime
Targus VersaVu Classic Flip cover for iPad Pro 12.9 Bundle deal on Targus VersaVu Classic Flip cover for iPad Pro 12.9" - Black
£134.90
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DS53 039915
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £5.98
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Cover
Colour: Black
Brand: Targus
Price Range Ex VAT: 0 - 50
