Targus VersaVu Classic Flip cover for iPad Pro 12.9" - Black
Quicklinx: DS53WS00 Mfr#: THZ651GL
The bestselling Targus Versavu range returns with a Multi-Gen case for the 12.9-inch iPad Pro, compatible with both the first and second generation. Featuring a smart-fit rotating tray, which offers hands free portrait and landscape viewing with access to iPad ports and camera. Sound scoops built into the case around your device speakers enhance and direct sound towards you. The front cover has a soft interior to protect the device screen and deep foam grooves to provide angles for comfortable viewing and typing. This iconic case design reveals the statement iPad Apple logo on the back of your device when in use.
Targus VersaVu Classic Case for iPad Pro (12.9-inch) 2nd gen./1st gen - flip cover for tablet
Flip cover for tablet
23.5 cm x 2.2 cm x 31.4 cm
498 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
23.5 cm
2.2 cm
31.4 cm
498 g
Lining Material
Plush fabric
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Waterproof, drop-proof
Cover Type
Flip cover
Open Type
Side
Additional Compartments
Apple Pencil
24 cm x 35.6 cm x 2.5 cm / 0.7 kg
Cover Features
Stand function, rotating
Max Height of Shock Resistance
1.22 m
Lifetime
