Targus VERSAVU 360 rotating Case for iPad 2 and iPad 3
Quicklinx: 80JVWS00 Mfr#: THZ156EU
Device Type: iPad
Type: iPad Case
Device Screen Size: [N/A]
Colour: Black
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
Targus Versavu cases feature a unique patent-pending rotating feature which allows you to turn your iPad 360° inside the case for a choice of viewing in either landscape or portrait. A hard shell back cover securely clicks onto your iPad to provide protection to the back and sides, whilst a durable front cover with super soft interior lining protects your iPad screen. Versavu cases are equipped with an integrated stylus loop which allows you to securely store your stylus. The case easily transforms into a hands free stand with a choice of 6 different viewing and typing positions. Recognised by the Independent newspaper as the best buy tablet case. Read the review.
Targus VersaVu 360° Rotating Stand & Case - case for tablet
Case for tablet
Screen Size Compatibility
9.7"
19.5 cm x 29 cm x 3 cm
340 g
Europe
Material
Faux leather, lychee polyurethane leather
Apple iPad (3rd generation); iPad 2; iPad with Retina display (4th generation)
19.5 cm
29 cm
3 cm
340 g
Material
Europe
Carrying Case
Case
Recommended Use
For tablet
9.7"
Protection
Scratch-resistant
Inner Dimensions
18.57 cm x 24.12 cm x 0.88 cm
Cover Features
Stand function
Lifetime
Apple iPad (3rd generation) , Apple iPad 2 , Apple iPad with Retina display (4th generation)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 80JV 039017
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £4.31
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: iPad
Type: iPad Case
Colour: Black
Brand: Targus
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
