Expand your view and connect your laptop to an external monitor via USB 3.0 SuperSpeed enabling instant connectivity and superb picture quality between your laptop and additional monitor. Choose between extending your desktop onto the secondary monitor to view two different applications at the same time, mirroring your laptop screen, or switching off your laptop screen and using the external monitor as your main screen. The multi monitor adapter offers improved productivity and combined with Targus USB 3.0 SuperSpeed Dual Video Docking Station you can support three external monitors, tripling your view.
- Targus Multi Monitor Adapter - adapter - DVI / USB
- Cable
- Adapter - DVI / USB
- Max Output Resolution
- 2048 x 1152
- Black
- Localisation
- Europe
- Connector
- USB Type A - male
- Connector (Second End)
- DVI-I - female
- USB 3.0
- 2-year warranty
- Cable Type
- Adapter
- Interface Supported
- DVI / USB
- USB 3.0
- Black
- Localisation
- Europe
Adapters & Converters
- 2048 x 1152
- Connector
- 9 pin USB Type A - male
- 24+5 pin combined DVI - female
- 9.5 cm
- 6 cm
- 2 cm
- 90 g
- Limited warranty - 2 years
