Targus Urban Explorer 15.6" Laptop Backpack Grey
Quicklinx: CS01WS00 Mfr#: TSB89704EU
£50.13 ex VAT
£60.15 inc VAT
Targus Urban Explorer Laptop Backpack is your go-to bag Monday through Sunday. The outdoor inspired design features a padded laptop sleeve and room for a tablet, phone, accessories and personal belongings, whether commuting to work or away for the weekend the water repellent material ensures your belongings are protected against the weather. Our unique AIR X FLOW back padding boosts airflow to keep you comfortable and cool. Ideal for cyclists with compression straps which can be tightened to maintain a slim profile and reflective panels help you stay visible in the dark, a discreet whistle on the chest strap also means you can call attention to yourself if you need to.
Targus Urban Explorer - notebook carrying backpack
Notebook carrying backpack
Grey
Product Material
Twill polyurethane
30.5 cm x 17 cm x 47 cm
910 g
Notebook Compatibility
15.6"
Reflective elements, water repellent, padded notebook compartment, AIR X FLOW back padding
Carrying Strap
Chest strap, adjustable padded shoulder straps
Product Material
Twill polyurethane
30.5 cm
17 cm
47 cm
910 g
15.6"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Mobile phone, personal accessories, bottle, tablet
Carrying Strap
Ventilated Back
Ventilated Back Type
Mesh material
24 litres
Grey
Limited warranty: - lifetime
