Targus Signature Folio Tablet Cover for Surface Pro 2017 - Grey
Quicklinx: F03LWS00 Mfr#: THZ681GL
Device Type: Surface Pro
Type: Cover
Colour: Grey
£12.39 ex VAT
£14.86 inc VAT
The Protective Folio Case is a light, form-fit case which wraps securely around your Microsoft Surface (2017) & Surface Pro 4. The two-piece design ensures your device is always protected: A shock-absorbing perfect-fit tray clicks securely onto the device and folds into a stand, while the removable folio cover wraps around and secures magnetically to provide screen protection on the go. This cover also has soft corners for added protection. This case can be used with or without your Type Cover keyboard.
Two-Piece DesignWith soft corners ensures all-round, form-fit protection for your Microsoft Surface (2017) & Surface Pro 4.Removable Wrap-Around Folio Cover Secures magnetically for screen protection on the go, while your device sits in a shock-absorbing protective tray for front, rear and side protection
Removable Wrap-Around Folio CoverSecures magnetically for screen protection on the go, while your device sits in a shock-absorbing protective tray for front, rear and side protection.
Both The Folio Cover And Protective Folio cover protects both device and keyboard when on the go.Tray Can Be Folded Back To use your Surface with the stand for comfortable viewing and convenient typing angles.
Works with or without Type Cover KeyboardFolio cover protects both device and keyboard when on the go.
  • Two-piece design
    With soft corners ensures all-round, form-fit protection for your device.
  • Removable wrap-around folio cover
Targus Signature Folio Wrap - flip cover for tablet
Flip cover for tablet
21 cm x 31 cm x 2.5 cm
530 g
Material
Polyurethane
Grey
Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6
21 cm
31 cm
2.5 cm
530 g
Material
Polyurethane
Grey
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Shockproof
Cover Type
Flip cover
Additional Compartments
Stylus
Cover Features
Stand function
2 years
Targus Signature Folio Tablet Cover for Surface Pro 2017 - Grey Bundle deal on Targus Signature Folio Tablet Cover for Surface Pro 2017 - Grey
£111.56
Type: Cover
Colour: Grey
Brand: Targus
Price Range Ex VAT: 0 - 50
