The SafePort Rugged Max Pro case is one of the best in tablet security. Specifically designed to offer protection for the harshest environments, this case fits perfectly to absorb shock and other potential damage.
Tough outer shell
It is made with a hardened polycarbonate shell with shock absorbing silicone. -
All-around protection
Case features built-in screen protector and silicone plugs over audio and power ports. The perfect-fit silicone plugs keep out dust and other hazardous materials. -
Added protection
Double padded corners for more protection when dropped. -
Tablet stand
It allows for hands-free viewing and features 360 degree rotation.
- Targus SafePORT Rugged Max Pro - protective case for tablet
- Product Type
- Protective case for tablet
- 19 cm x 29.6 cm x 3.8 cm
- 440 g
- Material
- Silicone, polycarbonate
- Black
- 1-year warranty
- Designed For
- Venue 10 Pro (5056)
- 19 cm
- 29.6 cm
- 3.8 cm
- 440 g
- Rugged
- Material
- Black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Protection
- Waterproof, shockproof, dust-resistant, drop-proof
- Carrying Strap
- Hand strap, shoulder carrying strap
- Cover Features
- Stand function
- 1 year
- Designed For
- Dell Venue 10 Pro (5056)
