Product
Targus SafeFit Samsung Tab A 9.7  Tablet Case - Red
Quicklinx: BJZ0WS00 Mfr#: THZ60703GL
The Targus SafeFit multi-fit tablet case is designed to secure and protect your Samsung 9.7-10.1” device. Safe Fit's shock absorbing multi-fit system secures your Samsung device safely inside the case- it grips & protect your tablet's four corners. Clever use of magnets and the multi-fit system means you can use your tablet camera from within the case.
  • Right fit, tight grip
    Your tablet is held securely and safely in place by a silicone system with reinforced shock-absorbing corners with just-enough stretch to grip Samsung devices with 9.7" to 10.1" screens.
  • All round protection
    Complete protection from everyday drops, bumps and knocks, the case surrounds your device in a soft interior with a durable front cover that can be secured with the elastic closure.
  • Angle your experience
    Position your tablet screen forward or backward for the optimal viewing angle. You can even create a convenient typing angle by folding the cover back to form a triangle stand.
Targus Safe Fit - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
10.1"
19 cm x 2.5 cm x 25 cm
300 g
Material
Polyurethane
Red
Samsung Galaxy Tab A (9.7 in)
19 cm
2.5 cm
25 cm
300 g
Material
Polyurethane
Red
Carrying Case
Protective cover
Recommended Use
For tablet
10.1"
Cover Type
Flip cover
Camera lens cutout, adjustable viewing angles, shock absorption, 4 silicone elastic holders
Cover Features
Stand function
Lifetime
