The Targus SafeFit multi-fit tablet case is designed to secure and protect your Samsung 9.7-10.1” device. Safe Fit's shock absorbing multi-fit system secures your Samsung device safely inside the case- it grips & protect your tablet's four corners. Clever use of magnets and the multi-fit system means you can use your tablet camera from within the case.
Right fit, tight grip
Your tablet is held securely and safely in place by a silicone system with reinforced shock-absorbing corners with just-enough stretch to grip Samsung devices with 9.7” to 10.1” screens. -
All round protection
Complete protection from everyday drops, bumps and knocks, the case surrounds your device in a soft interior with a durable front cover that can be secured with the elastic closure. -
Angle your experience
Position your tablet screen forward or backward for the optimal viewing angle. You can even create a convenient typing angle by folding the cover back to form a triangle stand.
- Targus Safe Fit - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10.1"
- 19 cm x 2.5 cm x 25 cm
- 300 g
- Material
- Polyurethane
- Blue
- Limited lifetime warranty
- Designed For
- Samsung Galaxy Tab A (9.7 in)
- 19 cm
- 2.5 cm
- 25 cm
- 300 g
- Material
- Polyurethane
- Blue
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10.1"
- Cover Type
- Flip cover
- Camera lens cutout, adjustable viewing angles, shock absorption, 4 silicone elastic holders
- Cover Features
- Stand function
- Lifetime
- Designed For
