Targus SafeFit Samsung Tab A 9.7  Tablet Case  - Black
Quicklinx: BJZ1WS00 Mfr#: THZ607GL
The Targus SafeFit multi-fit tablet case is designed to secure and protect your Samsung 9.7-10.1” device. Safe Fit's shock absorbing multi-fit system secures your Samsung device safely inside the case- it grips & protect your tablet's four corners. Clever use of magnets and the multi-fit system means you can use your tablet camera from within the case.
Targus Safe Fit - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
10.1"
19 cm x 2.5 cm x 25 cm
300 g
Material
Polyurethane
Samsung Galaxy Tab A (9.7 in)
19 cm
2.5 cm
25 cm
300 g
Material
Polyurethane
Carrying Case
Protective cover
Recommended Use
For tablet
10.1"
Cover Type
Flip cover
Camera lens cutout, adjustable viewing angles, shock absorption, 4 silicone elastic holders
Cover Features
Stand function
Lifetime
