Targus Rolling Notebook Backpack
Quicklinx: 4QQJWS00 Mfr#: TSB700EU
Device Type: Laptop
Type: Bags & Cases
Device Screen Size: [N/A]
Colour: Black
26 in stock
£62.51 ex VAT
£75.01 inc VAT
Targus’ first Rolling Notebook Backpack combines the best of both worlds. At first glance you can see that it is a stylish, durable backpack with plenty of features but look a bit closer and you can see that it is also a roller. The TSB700 glides on in-line skate wheels and includes a 2-tier telescoping locking handle for easy navigation. A protective rear flap holds the shoulder straps in place when using it as a roller, then lower the flap to cover the wheels for greater comfort when in backpack mode. For additional convenience it has a handle grip on the bottom of the case that allows for easy lifting into your car or an airline overhead compartment. Other features include a padded, removable slip case for notebooks with 15" - 15.6” screens, top front pocket with protective lining for iPod/MP3 players, PDA or sunglasses, bottom front pocket with business card holder, pen loops and key clip, a main compartment with plenty of file and accessory storage, a large side pocket, even a side mesh water bottle holder. Stylish, practical and ready to go, this case has it all.
Targus Sport Rolling notebook carrying backpack
Notebook carrying backpack
Product Material
Polyester
36 cm x 22 cm x 51.5 cm
2.45 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 15.6" / 38.1 cm - 39.6 cm
Padded notebook compartment
Carrying Strap
Padded shoulder straps, adjustable sternum strap
Telescopic Handle / Wheels
Product Material
Polyester
36 cm
22 cm
51.5 cm
2.45 kg
15.6"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Personal accessories, bottle, clothing, stash pocket
Carrying Strap
Closure Type
Zipper
Ventilated Back
Ventilated Back Type
Mesh material
30 litres
Wheels Qty
2
Limited warranty - lifetime
Targus Rolling Notebook Backpack Bundle deal on Targus Rolling Notebook Backpack
£161.68
Device Type: Laptop
Type: Bags & Cases
Colour: Black
Brand: Targus
Price Range Ex VAT: 50 - 100
