Targus Pro-Tek Rotating Case for iPad Pro 11" - Black
Quicklinx: DYPQWS00 Mfr#: THZ743GL
Device Type: iPad Pro
Type: Case
Device Screen Size: 11"
Colour: Black
£36.81 ex VAT
£44.17 inc VAT
The Pro-Tek Rotating Case for 11-in. iPad Pro delivers practical protection and adaptable good looks with Targus's signature geometric Pro-Tek design. Rugged corner bumpers add impact protection. A custom-molded interior tray with enhanced corners defends against damage. The magnetic wrap closure secures and safeguards on-the-go. And, like other Targus cases, it offers military grade protection for drops up to 4 feet*.
Chameleon-like adaptability lets you adjust with ease to meet your needs. A simple flip transforms your case into a sturdy stand for comfortable typing. Flip again for easy viewing, with smooth rotation from portrait-to-landscape positioning. Your ideal viewing angle is assured thanks to virtually infinite options. Deep grooves anchor the edge to ensure stability. Precision cutouts offer easy access to your controls, ports, and camera. Even your audio gets a boost with audio scoops that deflect sound toward the user. And your Apple Pencil or stylus is always at-the-ready thanks to the convenient integrated loop.
Military Grade Drop ProtectionMinor drops and bumps are no problem for this sturdy, structured case. In fact, the case passes rigorous MIL-STD 810G testing to ensure it can protect your 11-in. iPad Pro from drops up to four feet.
Easy Portrait and Landscape ViewingPatented 360-degree rotation makes it easy to switch from portrait to landscape modes and back again and use the stand function in either mode. That way, video conferences and FaceTime aren't locked into landscape mode.
Full Access, Full FunctionalityA full-coverage patented molded tray with reinforced corners allows access to all ports, buttons, and controls. Precision cutouts ensure the camera is accessible for photos or videos without removing your iPad Pro from the case.
Swipe or Type with EaseThe textured, non-slip interior lets you position your iPad in a virtually infinite range of reading or viewing angles for watching videos or interacting with your screen or flip the cover back for a comfortable typing angle.
Targus Pro-Tek Rotating - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
11"
18 cm x 2.5 cm x 26 cm
350 g
Material
Polyurethane
Apple 11-inch iPad Pro (1st generation, 2nd generation)
18 cm
2.5 cm
26 cm
350 g
Rugged
Material
Polyurethane
Carrying Case
Protective cover
Recommended Use
For tablet
11"
Protection
Impact protection, drop-proof
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Additional Compartments
Apple Pencil
Cover Features
Stand function, rotating
MIL-STD 810G 516.6 Procedure IV
Max Height of Drop Protection
1.22 m
Lifetime
Type: Case
Colour: Black
Brand: Targus
