Targus ProTek iPad Case is multi-fit, compatible with iPad 2018/2017, 9.7" iPad Pro & iPad Air 2. Advanced protection for your tablet the shock-absorbing case has a tough outer edge with side & corner protection with access to iPad ports and camera. The engineered case design is easy to grip and water-resistant with a reassuring elastic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
- Targus Pro-Tek Handheld Folio - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 9.7"
- 18.5 cm x 1.5 cm x 26 cm
- 330 g
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- Black
- 2-year warranty
- Designed For
- Apple 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air 2
- 18.5 cm
- 1.5 cm
- 26 cm
- 330 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Shockproof, dust-resistant, dirt-resistant, impact protection, water-resistant, drop protection, scuff-resistant
- Cover Type
- Flip cover
- Open Type
- Side
- Carrying Strap
- Hand strap
- Closure Type
- Elastic band closure
- Additional Compartments
- Apple Pencil
- Cover Features
- Stand function
- Max Height of Drop Protection
- 1.8 m
- 2 years
- Designed For
- Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air 2
