Targus Pro-Tek Handheld Folio Flip cover for iPad 9.7" - Grey
Quicklinx: DYPLWS00 Mfr#: THD483GLZ
Type: Cover
Device Screen Size: 9.7"
Colour: Black
Hurry, only 3 left in stock!
£40.24 ex VAT
£48.28 inc VAT
Targus ProTek iPad Case is multi-fit, compatible with iPad 2018/2017, 9.7" iPad Pro & iPad Air 2. Advanced protection for your tablet the shock-absorbing case has a tough outer edge with side & corner protection with access to iPad ports and camera. The engineered case design is easy to grip and water-resistant with a reassuring elastic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
Targus Pro-Tek Handheld Folio - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
9.7"
18.5 cm x 1.5 cm x 26 cm
330 g
Material
Polycarbonate, thermoplastic polyurethane (TPU)
Apple 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air 2
18.5 cm
1.5 cm
26 cm
330 g
Material
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Shockproof, dust-resistant, dirt-resistant, impact protection, water-resistant, drop protection, scuff-resistant
Cover Type
Flip cover
Open Type
Side
Carrying Strap
Hand strap
Closure Type
Elastic band closure
Additional Compartments
Apple Pencil
Cover Features
Stand function
Max Height of Drop Protection
1.8 m
2 years
Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air 2
Type: Cover
Colour: Black
Brand: Targus
Price Range Ex VAT: 0 - 50
