Targus Pro-Tek Handheld Folio Flip cover for iPad 9.7" - Grey
Quicklinx: DYPLWS00 Mfr#: THD483GLZ
Type: Cover
Device Screen Size: 9.7"
Colour: Grey
Hurry, only 1 left in stock!
£17.92 ex VAT
£21.50 inc VAT
Targus ProTek iPad Case is multi-fit, compatible with iPad 2018/2017, 9.7" iPad Pro & iPad Air 2. Advanced protection for your tablet the shock-absorbing case has a tough outer edge with side & corner protection with access to iPad ports and camera. The engineered case design is easy to grip and water-resistant with a reassuring elastic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
Targus Pro-Tek Handheld Folio - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
9.7"
330 g
Material
Polycarbonate, thermoplastic polyurethane (TPU)
Grey
Apple 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air 2
330 g
Material
Grey
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Waterproof, dust-resistant, drop-proof
Cover Type
Flip cover
Open Type
Side
Cover Features
Stand function
MIL-STD 810G, IP54
Max Height of Shock Resistance
1.8 m
2 years
Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air 2
Targus Pro-Tek Handheld Folio Flip cover for iPad 9.7 Bundle deal on Targus Pro-Tek Handheld Folio Flip cover for iPad 9.7" - Grey
£117.09
Type: Cover
Colour: Grey
Brand: Targus
Price Range Ex VAT: 0 - 50
