Targus Pro-Tek Case fits the 10.5-inch iPad Pro offering advanced engineered protection for your tablet. The shock-absorbing form-fit tray has a tough outer edge with access to iPad ports and camera. Sound scoops built into the case around your device speakers enhance and direct sound towards you. The engineered case design is easy to grip and water-resistant with a reassuring magnetic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
- Targus Pro-Tek - flip cover for tablet
- Product Type
- Flip cover for tablet
- 18.5 cm x 2 cm x 25.8 cm
- 400 g
- Black
- Limited lifetime warranty
- Designed For
- Apple 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
- 18.5 cm
- 2 cm
- 25.8 cm
- 400 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Waterproof, shockproof
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Magnetic closure
- Cover Features
- Stand function
- Max Height of Shock Resistance
- 1.2 m
- Lifetime
- Designed For
- Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£112.66
