Targus Pro-Tek Flip Cover for Apple iPad Pro 10.5" - Black
Quicklinx: DYPNWS00 Mfr#: THZ673GL
Device Type: iPad Pro
Type: Cover
Device Screen Size: 9.7"
Colour: Black
£28.24 ex VAT
£33.88 inc VAT
Targus Pro-Tek Case fits the 10.5-inch iPad Pro offering advanced engineered protection for your tablet. The shock-absorbing form-fit tray has a tough outer edge with access to iPad ports and camera. Sound scoops built into the case around your device speakers enhance and direct sound towards you. The engineered case design is easy to grip and water-resistant with a reassuring magnetic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
Targus Pro-Tek - flip cover for tablet
Flip cover for tablet
18.5 cm x 2 cm x 25.8 cm
400 g
Apple 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
18.5 cm
2 cm
25.8 cm
400 g
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Waterproof, shockproof
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Cover Features
Stand function
Max Height of Shock Resistance
1.2 m
Lifetime
Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
Targus Pro-Tek Flip Cover for Apple iPad Pro 10.5 Bundle deal on Targus Pro-Tek Flip Cover for Apple iPad Pro 10.5" - Black
£127.41
Type: Cover
Colour: Black
Brand: Targus
Price Range Ex VAT: 0 - 50
