Keep your business your business with a Targus Privacy Screen. Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
- Targus Privacy Screen - display privacy filter - 27" wide
- Product Type
- Display privacy filter
- Installation Type
- Removable
- Display Screen Size Compatibility
- 27" wide
- 60 cm x 0.1 cm x 33.5 cm
- 130 g
- 2-year warranty
- Product Type
- 27" wide
- 60 cm - 0.1 cm - 33.5 cm
- 130 g
Display Filter
- Installation Type
- Removable
- Aspect Ratio
- 16:9
- Surface Finish
- Glossy/matte
- Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
- Limited warranty - 2 years
