Targus Privacy Screen 24" Widescreen (16:9)
Quicklinx: BBSPWS00 Mfr#: ASF24W9EU
Stock Status: In Stock, Used Stock
44 in stock
£66.14 ex VAT
£79.36 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
Targus Privacy Screen 24" Widescreen (16:9) display privacy filter
Display privacy filter
Transparent
53.1 cm 29.8 cm
350 g
Display Screen Size Compatibility
24" wide
Anti-glare
Dell P2412H, P2412H-HF, ST2420L
53.1 cm
29.8 cm
350 g
24" wide
Transparent
Anti-glare
Targus Privacy Screen 24 Bundle deal on Targus Privacy Screen 24" Widescreen (16:9)
£165.31
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BBSP 038941
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £9.27
Ref: BBSP 038942
Condition: Customer return - item has been used but is in excellent condition
Ref: BBSP 039516
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £9.27
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Targus
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
