Targus Privacy Screen 24" Widescreen (16:9)
Quicklinx: BBSPWS00 Mfr#: ASF24W9EU
Hurry, only 2 left in stock!
£41.78 ex VAT
£50.13 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
Targus Privacy Screen - display privacy filter - 24" wide
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
24" wide
53 cm 30 cm
110 g
Dell P2412H, P2412H-HF, ST2420L
24" wide
53 cm 30 cm
110 g
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Brand: Targus
Price Range Ex VAT: 0 - 50
