Product
Targus Privacy Screen 24" Widescreen (16:10)
Quicklinx: BBSRWS00 Mfr#: ASF24WEU
Stock Status: In Stock, Used Stock
£66.14 ex VAT
£79.36 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
Targus Privacy Screen 24" Widescreen (16:10) - display privacy filter - 24" wide
Display privacy filter
Transparent black
Display Screen Size Compatibility
24" wide
51.79 cm 32.35 cm
2 years warranty
24" wide
51.79 cm 32.35 cm
Transparent black
Mounting Kit
Included
Anti-glare, Micro-Louver technology
Targus Privacy Screen 24 Bundle deal on Targus Privacy Screen 24" Widescreen (16:10)
£165.90
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BBSR 037273
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £9.27
Ref: BBSR 037806
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £9.27
Ref: BBSR 038198
Condition: Customer return - item has been used and shows signs of use
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Targus
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
