Targus High-Impact Laptop Slipcase liberates laptop users to take their device anywhere, safely. This slim, protective case works as a folio, can throw on a shoulder strap, or toss it in another bag. Ready for any situation, it passes military grade specifications and protects your hardware from 4ft drops, wind, rain, vibration and dust. USA Military-Grade as standard, worry no more about dropping your laptop, with the ability to withstand twenty-six 4 foot drops, high vibrations for 18 hours, up to 59 feet per second of dust for 3 hours, and approximately 7 inches of rain per hour, the High-Impact Slipcase has earned its USA Military-Spec approval.All round protection, great care was taken in the design, from reinforced, shock absorbing corners to the soft, microfibre interior and a completely padded surface to a weather hood to keep out the elements. Incredibly light but heavy on protection. Throw the slipcase in another bag; tuck it under your arm, or add-on the included shoulder strap. No matter how you transport it, your device is surrounded in protection.
All-round protection
Great care was taken in the design, from reinforced, shock-absorbing corners to the soft, microfiber interior and a completely padded surface to a weather hood to keep out the elements. -
- Targus Mil-Spec Vertical Hooded Slipcase - notebook carrying case
- Product Type
- Notebook carrying case
- Grey, black
- Product Material
- Polyester
- 24 cm x 5 cm x 34 cm
- 440 g
- Notebook Compatibility
- 12"
- Dustproof, rainproof, vibration-proof, microfibre interior, drop-proof, shock absorption
- Carrying Strap
- Shoulder carrying strap
- Localisation
- Europe
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 24 cm
- 5 cm
- 34 cm
- 440 g
- 12"
- Additional Compartments
- Personal accessories
- Carrying Strap
- Grey, black
- Localisation
- Europe
- Limited warranty: - lifetime
