The Targus 17.3” CityGear Travel Laptop Roller is ideal for the travelling professional with a need for storage. This uniquely and spaciously designed case allows you to comfortably store your large-size laptop in addition to clothing and personal accessories. The case features a dedicated iPad® pocket that can fit an eReader or 10” tablet device, a zip-down workstation with pen loops, business card holders and a zippered mesh pocket for additional accessory items. A special overnight luggage section provides enough room for a change of clothes for short business trips. The smooth-rolling wheels and telescoping handle make this rolling case the perfect travel companion.
- Targus CityGear XL Laptop Roller - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester
- 47 cm x 25 cm x 43 cm
- 3.82 kg
- Notebook Compatibility
- 17.3"
- Zippered, padded, wheels, pen loop, key clip, business card holder
- Carrying Strap
- Hand grip, rolling luggage strap
- Telescopic Handle / Wheels
- Localisation
- European Union
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 47 cm
- 25 cm
- 43 cm
- 3.82 kg
- 17.3"
- Notebook Compatibility Dimensions
- 42.2 cm x 28.7 cm x 3.8 cm
- Additional Compartments
- Pens, clothing, keys, business cards, mobile accessories
- Carrying Strap
- Black
- Localisation
- European Union
- Limited warranty: - lifetime
