Your basket is empty
Targus Metro Rolling Notebook Case
Quicklinx: 3NMVWS00 Mfr#: TCG717
The Targus 17.3” CityGear Travel Laptop Roller is ideal for the travelling professional with a need for storage. This uniquely and spaciously designed case allows you to comfortably store your large-size laptop in addition to clothing and personal accessories. The case features a dedicated iPad® pocket that can fit an eReader or 10” tablet device, a zip-down workstation with pen loops, business card holders and a zippered mesh pocket for additional accessory items. A special overnight luggage section provides enough room for a change of clothes for short business trips. The smooth-rolling wheels and telescoping handle make this rolling case the perfect travel companion.
Targus 17" Rolling Travel Laptop Case - notebook carrying case
Notebook carrying case
Product Material
Nylon
45.7 cm x 38.1 cm x 25.4 cm
3.82 kg
Notebook Compatibility
17"
Product Material
Nylon
45.7 cm
38.1 cm
25.4 cm
3.82 kg
46.4 cm x 25.4 cm x 40.6 cm
17"
Notebook Compatibility Dimensions
42 cm x 33 cm x 5.7 cm
Limited warranty - lifetime
