Your basket is empty
Targus Lap Chill Mini
Quicklinx: BBR9WS00 Mfr#: AWE79EU
Targus Compact Lap Chill Mat is a USB powered cooling mat for your laptop. Compact and powerful this low profile design actively cools the base of your laptop using two internal fans. The fans are positioned below a ventilated surface which allows heat to dissipate and air to flow around your laptop. Suitable for up to 15.6" laptops the Compact Lap Chill Mat is wrapped with soft touch padding for increased comfort, making it ideal for use on your lap or on a desk with its flat base and rubber pads keeping your laptop stable. The wrap around USB cable and compact, low profile design of the mat makes it easy to store.
Targus Dual Fan Chill Mat - notebook stand
Notebook stand
Built-in Devices
2 cooling fans
Grey, black
Fans Qty
Dual
23.49 cm x 2.54 cm x 33.65 cm
625 g
Cord wrap
1 year warranty
Notebook stand
Built-in Devices
2 cooling fans
23.49 cm
2.54 cm
33.65 cm
625 g
Grey, black
Heatsink & Fan
Fans Qty
2
Cord wrap
RoHS
Limited warranty - 1 year
BBR9 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.03
BBR9 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.28
BBR9 C2G 2-Port USB 2.0 Manual Switch In Stock £16.49
BBR9 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.53
BBR9 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BBR9 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.20
