Targus GRID Advanced Backpack means you can carry your tech with you anywhere, safely. This spacious backpack fits laptops up to 16” screen size and has a 32 litre capacity. Ready for any situation, it passes military specification protection standard and protects your hardware from 4ft drops, wind, rain and dust. This bag is designed for all round protection of your devices with separate compartments for your laptop, tablet and valuables. When it’s loaded full of your stuff, the padded and vented shoulder straps and back support provide a comfortable, well balanced fit. Clever StorageTargus Grid Advanced Backpack is designed for protecting and transporting laptops up to 16” screen size. It features separate compartments for your laptop and tablet and a hidden travel pocket in the back panel for valuables. It has a 32L capacity. USA Military-Grade As StandardWorry no more about dropping your laptop, with the ability to withstand twenty-six 4ft drops, high vibrations for 18 hours, up to 59 feet per second of dust for 3 hours and approximately 7 inches of rain per hour, the High-Impact Grid Backpack has passed USA Military-Spec testing. All Round Protectionbag has a 360° protective frame and shock-absorbing bumpers on the base as well as a suspended laptop vault to ensure your tech is protected from every angle. Carry In Comfort Vented, padded shoulder straps and a lumbar support panel in the back promote airflow and distribute weight evenly so you can carry your belongings comfortably.
Clever storage
Targus Grid Advanced Backpack is designed for protecting and transporting laptops up to 16" screen size. It features separate compartments for your laptop and tablet and a hidden travel pocket in the back panel for valuables. It has a 32L capacity. -
USA Military-Grade as standard
Worry no more about dropping your laptop, with the ability to withstand twenty-six 4ft drops, high vibrations for 18 hours, up to 59 feet per second of dust for 3 hours and approximately 7 inches of rain per hour, the High-Impact Grid Backpack has passed USA Military-Spec testing. -
All round protection
bag has a 360° protective frame and shock-absorbing bumpers on the base as well as a suspended laptop vault to ensure your tech is protected from every angle. -
Carry in comfort
- Targus Grid Advanced - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- Polyester
- 33 cm x 18 cm x 52 cm
- 980 g
- Notebook Compatibility
- 16"
- Rainproof, dust resistant, shock absorption, padded shoulder straps
- Carrying Strap
- Shoulder carrying straps, top carry handle
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 33 cm
- 18 cm
- 52 cm
- 980 g
- 16"
- Notebook Compatibility Dimensions
- 37.5 cm x 26 cm x 3.9 cm
- Additional Compartments
- Bottle, tablet
- Carrying Strap
- Black
- Limited warranty: - lifetime
