Targus Fit N’ Grip Universal tablet case is designed to secure and protect your 9-10” device. Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case.
- Targus Fit-N-Grip Universal - flip cover for tablet / eBook reader
- Product Type
- Flip cover for tablet / eBook reader
- Screen Size Compatibility
- 10"
- 20 cm x 26.5 cm x 2.5 cm
- 330 g
- Localisation
- Europe
- Material
- Polyurethane
- Black
- Limited lifetime warranty
- 20 cm
- 26.5 cm
- 2.5 cm
- 330 g
- Material
- Polyurethane
- Black
- Localisation
- Europe
Carrying Case
- Protective cover
- Recommended Use
- For tablet / eBook reader
- 10"
- Cover Type
- Flip cover
- Open Type
- Side
- Corner protection system, camera lens cutout, shock absorption
- Cover Features
- Stand function
- Lifetime
