Targus Fit N Grip Universal 9-10  Tablet Case - Black
Quicklinx: BJYPWS00 Mfr#: THZ591EU
Targus Fit N’ Grip Universal tablet case is designed to secure and protect your 9-10” device.  Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case.
Targus Fit-N-Grip Universal - flip cover for tablet / eBook reader
Flip cover for tablet / eBook reader
Screen Size Compatibility
10"
20 cm x 26.5 cm x 2.5 cm
330 g
Europe
Material
Polyurethane
20 cm
26.5 cm
2.5 cm
330 g
Material
Polyurethane
Europe
Carrying Case
Protective cover
Recommended Use
For tablet / eBook reader
10"
Cover Type
Flip cover
Open Type
Side
Corner protection system, camera lens cutout, shock absorption
Cover Features
Stand function
Lifetime
