Targus Fit N Grip Universal 7-8  Tablet Case - Blue
Quicklinx: BJYCWS00 Mfr#: THZ58901EU
Colour: Blue
£12.19 ex VAT
£14.62 inc VAT
Targus Fit N’ Grip Universal tablet case is designed to secure and protect your 7-8” device.  Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case.
  • Right fit, tight grip
    Your tablet is held securely and safely in place by a silicone system with reinforced shock-absorbing corners with just-enough stretch to grip devices with 7" to 8" screens.
  • All around protection from everyday drops, bumps and knock
    The case surrounds your device in a soft interior with a durable front cover that is secured with an elastic closure.
  • Angle your experience
    Position your tablet forward or backward for the optimal viewing angle. You can even create a convenient typing angle by folding the cover back to form a triangle stand.
  • Flip, point, shoot
    Taking a photo with your tablet's camera has never been easier. Simply fold the corner of the back cover to reveal your camera lens.
Targus Fit-N-Grip Universal - flip cover for tablet / eBook reader
Flip cover for tablet / eBook reader
Screen Size Compatibility
8"
15 cm x 21.5 cm x 2 cm
160 g
Europe
Material
Polyurethane
Blue
15 cm
21.5 cm
2 cm
160 g
Material
Polyurethane
Blue
Europe
Carrying Case
Protective cover
Recommended Use
For tablet / eBook reader
8"
Cover Type
Flip cover
Open Type
Side
Corner protection system, camera lens cutout, shock absorption
Cover Features
Stand function
Lifetime
Colour: Blue
Brand: Targus
