Targus Fit N Grip Universal 7-8  Tablet Case  - Black
Quicklinx: BJYGWS00 Mfr#: THZ589EU
Targus Fit N’ Grip Universal tablet case is designed to secure and protect your 7-8” device.  Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case.
Targus Fit-N-Grip Universal - flip cover for tablet / eBook reader
Flip cover for tablet / eBook reader
Screen Size Compatibility
8"
15 cm x 21.5 cm x 2 cm
160 g
Europe
Material
Polyurethane
15 cm
21.5 cm
2 cm
160 g
Material
Polyurethane
Europe
Carrying Case
Protective cover
Recommended Use
For tablet / eBook reader
8"
Cover Type
Flip cover
Open Type
Side
Corner protection system, camera lens cutout, shock absorption
Cover Features
Stand function
Lifetime
