Targus Fit N Grip Universal 12.2" Black
Quicklinx: BPYHWS00 Mfr#: THZ622GL
Targus Fit N’ Grip Universal tablet case is designed to secure and protect your 12.2” device. Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case. Right Fit, tight grip. Your tablet is held securely and safely in place by a silicone system with reinforced shock-absorbing corners with just-enough stretch to grip devices with 12.2" screens. All around protection from everyday drops, bumps and knocks, the case surrounds your device in a soft interior with a durable front cover that is secured with an elastic closure.Angle Your Experience.Position your tablet forward or backward for the optimal viewing angle. You can even create a convenient typing angle by folding the cover back to form a triangle stand. Flip, Point, Shoot. Taking a photo with your tablet’s camera has never been easier. Simply fold the corner of the back cover to reveal your camera lens.
  • Right fit, tight grip
  • All around protection
  • Angle your experience
  • Flip, point, shoot
    Taking a photo with your tablet's camera has never been easier. Simply fold the corner of the back cover to reveal your camera lens.
Targus Fit-N-Grip Universal - flip cover for tablet / eBook reader
Flip cover for tablet / eBook reader
Screen Size Compatibility
12.2"
23 cm x 31 cm x 3 cm
Material
Polyurethane
23 cm
31 cm
3 cm
Material
Polyurethane
Carrying Case
Protective cover
Recommended Use
For tablet / eBook reader
12.2"
Protection
Drop-proof
Cover Type
Flip cover
Open Type
Side
22.5 cm x 2.5 cm x 31.1 cm
Cover Features
Stand function
Lifetime
