Targus Fit N’ Grip Universal 360° Rotating tablet case is designed to secure and protect your 9-10” device. Fit & Grip is a stretchy shock-absorbing silicone system which grips your tablet on all four corners and secures safely inside the case. Clever use of magnets and the Fit & Grip system means you can use your tablet camera from inside the case. Also enjoy a seamless transition between portrait and landscape viewing with rotating cradle.
Right fit, tight grip
Your tablet is held securely and safely in place by a silicone system with reinforced shock-absorbing corners with just-enough stretch to grip devices with 7" to 8" screens. -
All around protection from everyday drops, bumps and knock
The case surrounds your device in a soft interior with a durable front cover that is secured with an elastic closure. -
Angle your experience
Position your tablet forward or backward for the optimal viewing angle. You can even create a convenient typing angle by folding the cover back to form a triangle stand. -
Flip, point, shoot
Taking a photo with your tablet's camera has never been easier. Simply fold the corner of the back cover to reveal your camera lens.
- Targus Fit-N-Grip Universal 360 - flip cover for tablet / eBook reader
- Product Type
- Flip cover for tablet / eBook reader
- Screen Size Compatibility
- 10"
- 20 cm x 26.5 cm x 2.5 cm
- 330 g
- Localisation
- Europe
- Material
- Polyurethane
- Blue
- Limited lifetime warranty
- 20 cm
- 26.5 cm
- 2.5 cm
- 330 g
- Material
- Polyurethane
- Blue
- Localisation
- Europe
Carrying Case
- Protective cover
- Recommended Use
- For tablet / eBook reader
- 10"
- Cover Type
- Flip cover
- Open Type
- Side
- Corner protection system, camera lens cutout, shock absorption
- Cover Features
- Stand function
- Lifetime
