Targus Ergo M-Pro Notebook Stand
Quicklinx: 6Z7CWS00 Mfr#: AWE04EU
Type: Stand
Device Screen Size: [N/A]
£50.79 ex VAT
£60.94 inc VAT
The Ergo M-Pro Notebook Stand is a compact, thin and lightweight ergonomic notebook stand. It has multiple tilt positions to hold the notebook in a vertical position and allows the notebook LCD to be used as the display while being positioned higher relative to eye level. The Ergo M-Pro Notebook Stand also incorporates a document holder which is positioned directly in front of the notebook user. When not in use, the Ergo M-Pro Notebook Stand will collapse into a relatively flat product, which can then be packed away easily for extended stays out of the office or indeed to take with you on the road. Compatible with all PC and Mac notebooks up to 17". Must be used in conjunction with a separate keyboard.Awarded Ergonomic Excellence by the Furniture Industry Research Association.
Targus Ergo M-Pro Notebook Stand notebook stand
Notebook stand
Silver, dark grey
Product Material
Plastic
31 cm x 23 cm x 20 cm
485 g
Notebook Compatibility
17"
Adjustable height
Notebook stand
Product Material
Plastic
31 cm
23 cm
20 cm
485 g
17"
Silver, dark grey
Adjustable height
Targus Ergo M-Pro Notebook Stand Bundle deal on Targus Ergo M-Pro Notebook Stand
£149.96
Type: Stand
Brand: Targus
Price Range Ex VAT: 50 - 100
