The Targus DEFCON CCL Coiled Cable Lock allows users to protect a laptop and its valuable data with this affordable security product.The Targus DEFCON CCL lock is a 6 ft cut-resistant, vinyl-coated, coiled, galvanized steel cable that loops around any secure object and easily attaches to your laptop’s lock slot. The coiled construction makes for a smaller form factor that is easy to travel with and keep out of the way while in use. The DEFCON CCL features a user-settable combination lock with up to 10,000 possible settings for added security. Ideal for use in the office, at school, dorms, hotel rooms or other highly populated areas where your laptop could be at risk.
- Targus DEFCON CL Laptop Computer Cable Lock - security cable lock
- Product Type
- Security cable lock
- Grey
- Product Material
- Galvanised steel
- Length
- 1.83 m
- 200 g
- Combination lock, coiled cord
- 2-year warranty
- Product Type
- Product Material
- Galvanised steel
- Length
- 1.83 m
- 200 g
- Grey
- Limited warranty: - 2 years
