The Targus Cord-Storing Optical Mouse features a patented cord storing design that retracts the 61cm long USB cord completely inside of the mouse for easy and tangle-free travel. The cord can also be adjusted to any langth and the ergonomic, ambidextrous mouse design helps prevent palm strain. Utilizing the latest 1,000 DPI optical technology for precise tracking, the Cord-Storing Optical Mouse helps keep the workspace neat without the clutter ao excess cables.
Optical sensor technology
1,000 dpi optical sensor provides improved accuracy and precise mouse movements. -
Dual-purpose design
This mouse is large enough for comfortable desktop use, yet small enough for the mobile user. -
Ergonomic
Ergonomic shape provides support to help prevent palm strain; designed for left and right handed users. -
Retractable cord
Retractable USB cable provides cable management for easy travel.
- Targus Cord-Storing - mouse - USB - grey, black
- Mouse
- Connectivity Technology
- Wired - USB
- Grey, black
- Orientation
- Right and left-handed
- 5.5 cm x 10 cm x 3.5 cm
- 70 g
- Localisation
- Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Retractable cable, scrolling wheel
- Cable Length
- 75 cm
- OS Required
- Apple MacOS, Microsoft Windows
- 2-year warranty
- Mouse
- Orientation
- 5.5 cm
- 10 cm
- 3.5 cm
- 70 g
- Grey, black
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Cable Length
- 75 cm
- 1 x USB - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
