The Targus Wireless Compact Laser Mouse is the perfect solution for mobile users who need to save space when using an external mouse. The sleek design provides added style, whilst the integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The high definition laser sensor provides enhanced precision and accuracy in your clutter free environment. The mouse also features a low power indication light and micro USB receiver which is small enough to leave permanently plugged into your computer alternatively using the built-in Stow-N-GoTM technology the USB receiver can be easily stored away inside the mouse itself, for safe travelling.
Optical Sensor technology
1000 DPI high-precision laser sensor technology accurately responds to mouse movements. -
Easy storage
Stow-N-go design helps portability by keeping the USB port stored inside the body of the mouse. -
Ergonomically designed
Provides long lasting comfort due to its sleek, ergonomically form.
- Targus Wireless Compact Laser - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- 4.5 cm x 8.3 cm x 3.3 cm
- 39 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- Battery
- 2 x AAA type
- OS Required
- Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 4.5 cm
- 8.3 cm
- 3.3 cm
- 39 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- 1000 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- RoHS
- AAA type
- Installed Qty
- 2
- Run Time (Up To)
- 5 months
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 2 years
