Targus Compact Optical Mouse - Black/Grey
Quicklinx: BBRNWS00 Mfr#: AMU75EU
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
£6.14 ex VAT
£7.36 inc VAT
The Targus Compact Blue Trace Mouse is the perfect solution for travellers who need to save space when using an external mouse. The integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The retractable cord adjusts allowing users to choose the length needed to save space in compact work environments. Featuring a standard USB connection, the mouse is ready to work out of the box. The sleek black and grey design provides added style, while the contoured shape provides ergonomic support for left and right handed users. At only 7.6cm long, the Targus Compact Blue Trace Mouse is small enough to conveniently carry in a laptop bag for comfort and productivity on the go.
  • Ultra-mini
    The ultra-mini form factor is designed for those looking to travel light.
  • Wired USB
    It connects to a laptop or desktop computer using an included cable with USB connector.
  • Optical
    Designed with an optical sensor, it is good for word-processing and Web use on smaller screens. Offers low power consumption for extended battery life.
  • Retractable cable
    Gently pull on the cable to reveal a built-in cable management system that easily rewinds and stores the full length of the cable for easy transportation.
Targus - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
4.5 cm x 8 cm x 2.5 cm
40 g
Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Retractable cable, scrolling wheel, Blue Trace Technology
Cable Length
76 cm
Apple MacOS X 10.4 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Mouse
Orientation
4.5 cm
8 cm
2.5 cm
40 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
76 cm
1 x USB - 4 pin USB Type A
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Targus
Price Range Ex VAT: 0 - 50
