Targus Compact Laptop and Tablet USB Charger - UK
Quicklinx: BBR5WS00 Mfr#: APA042UK
£43.66 ex VAT
£52.39 inc VAT
The Targus Compact Charger for Laptop & USB Tablet is a 90 watt adapter that allows you to quickly charge a laptop and USB tablet or smartphone at the same time from a wall socket. Sized for travel, this charger is 25% smaller than most conventional power adapters and comes with a 2.1A USB fast charging port that connects with your USB devices charging cable providing the same charging speed as your original charger. Featuring built-in surge protection to keep all of your mobile devices safe from unexpected surges and spikes, this reliable adapter includes 7 connector tips to support Acer, Compaq, Dell, HP, IBM, Lenovo, Sony and Toshiba right out of the box. This charger is also compatible with iPad, iPad 2, iPhone, BlackBerry, Android and other tablet and phone devices with a USB charging capability.
Targus Compact Laptop & USB Tablet Charger - power adapter - 90 Watt
Power adapter - external
420 g
United Kingdom
Input Voltage
AC
Output Voltage
DC 19 V
Power Capacity
90 Watt
Output connectors
1 x 4 pin USB Type A - 5 V - 2.1 A , 1 x power DC jack - 19 V - 4.74 A
10 power tips
11 cm x 6 cm x 1.5 cm
United Kingdom
Input Voltage
AC
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
Output Voltage
DC 19 V
Max Electric Current
4.74 A
Power Capacity
90 Watt
10 power tips
Power cable (UK) - integrated - 1.8 m , Power cable - detachable - 1.8 m
Surge protection
11 cm
6 cm
1.5 cm
420 g
BBR5 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.98
BBR5 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.90
BBR5 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.13
BBR5 C2G USB Superbooster Extender Kit In Stock £35.89
Brand: Targus
Price Range Ex VAT: 0 - 50
