The Targus Compact Charger for Laptop & USB Tablet is a 90 watt adapter that allows you to quickly charge a laptop and USB tablet or smartphone at the same time from a wall socket. Sized for travel, this charger is 25% smaller than most conventional power adapters and comes with a 2.1A USB fast charging port that connects with your USB devices charging cable providing the same charging speed as your original charger. Featuring built-in surge protection to keep all of your mobile devices safe from unexpected surges and spikes, this reliable adapter includes 7 connector tips to support Acer, Compaq, Dell, HP, IBM, Lenovo, Sony and Toshiba right out of the box. This charger is also compatible with iPad, iPad 2, iPhone, BlackBerry, Android and other tablet and phone devices with a USB charging capability.
- Targus Compact Laptop & USB Tablet Charger - power adapter - 90 Watt
- Power adapter - external
- 420 g
- Localisation
- United Kingdom
- Input Voltage
- AC
- Output Voltage
- DC 19 V
- Power Capacity
- 90 Watt
- Output connectors
- 1 x 4 pin USB Type A - 5 V - 2.1 A , 1 x power DC jack - 19 V - 4.74 A
- Included Accessories
- 10 power tips
- Black
- 11 cm x 6 cm x 1.5 cm
- 2-year warranty
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- DC 19 V
- Max Electric Current
- 4.74 A
- Power Capacity
- 90 Watt
- 10 power tips
- Cables Included
- Power cable (UK) - integrated - 1.8 m , Power cable - detachable - 1.8 m
- Surge protection
- Limited warranty - 2 years
- 11 cm
- 6 cm
- 1.5 cm
- 420 g
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.98 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.90 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £12.13 |
C2G USB Superbooster Extender Kit | In Stock | £35.89 |
