The Targus Compact BlueTrace Mouse with a stylish and contemporary design is the perfect solution for travelers who need to save space when using an external mouse. The integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The Blue Trace technology combines the power of an optical mouse with the precision of a laser mouse for remarkable tracking on almost any surface. The retractable cord adjusts allowing users to choose the length needed to save space in compact work environments. Featuring a standard USB connection, the mouse is ready to work out of the box. At only 7.6cm long, the Targus Compact Optical Mouse is small enough to conveniently carry in a laptop bag for comfort and productivity on the go.
- Targus Compact Laptop - mouse - USB - white, red
- Mouse
- Connectivity Technology
- Wired - USB
- White, red
- Orientation
- Right and left-handed
- 4.5 cm x 7.6 cm x 2.5 cm
- 40 g
- Localisation
- Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Retractable cable, scrolling wheel, Blue Trace Technology
- Cables Included
- 1 x USB cable - integrated
- 2-year warranty
- Mouse
- Orientation
- 4.5 cm
- 7.6 cm
- 2.5 cm
- 40 g
- White, red
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1 x USB - 4 pin USB Type A
- Cables Included
- Limited warranty - 2 years
