Targus CleanVu Screen Cleaning Pad
Quicklinx: BC23WS00 Mfr#: TXA002EU
13 in stock
£4.16 ex VAT
£4.99 inc VAT
The Targus CleanVu™ Cleaning Pad offers an ideal way to effectively remove fingerprints and residue from the screen without using a cleaning solution. The reusable wipe is sized perfectly for the iPad/touchscreen tablets and features a durable faux leather backing with built-in handle for easy use. The cleaning pad material is made of soft, scratch-resistant faux suede that is safe to use on the screen. CleanVu cleaning pads can be used solo or in conjunction with the Targus Zierra Case which actually stores inside of the case. Compact for easy travel, CleanVu pads are a simple and effective screen wipe for iPads and most touchscreen tablet devices.
Targus CleanVu Cleaning Pad - cleaning pad
Cleaning pad
7.6 cm x 7.6 cm
44 g
Cleaning pad
7.6 cm
7.6 cm
44 g
Lifetime
Targus CleanVu Screen Cleaning Pad Bundle deal on Targus CleanVu Screen Cleaning Pad
£103.33
Brand: Targus
Price Range Ex VAT: 0 - 50
