Targus CleanVu Screen Cleaning Pad
Quicklinx: BC23WS00 Mfr#: TXA002EU
£4.99 ex VAT
£5.98 inc VAT
The Targus CleanVu™ Cleaning Pad offers an ideal way to effectively remove fingerprints and residue from the screen without using a cleaning solution. The reusable wipe is sized perfectly for the iPad/touchscreen tablets and features a durable faux leather backing with built-in handle for easy use. The cleaning pad material is made of soft, scratch-resistant faux suede that is safe to use on the screen. CleanVu cleaning pads can be used solo or in conjunction with the Targus Zierra Case which actually stores inside of the case. Compact for easy travel, CleanVu pads are a simple and effective screen wipe for iPads and most touchscreen tablet devices.
  • Efficient cleaning
    Designed specifically for tablets, the Targus CleanVu cleaning pad offers an effective solution for removing fingerprints and smudges, ensuring your device looks pristine.
  • Durable materials
    Crafted from PET and faux leather, this cleaning pad combines durability with a soft touch, providing scratch-resistant protection to keep your tablet's screen in top condition.
Targus CleanVu - cleaning pad for tablet
Cleaning pad
Intended For
Tablet
Protection
Scratch-resistant
Product Material
PET, faux leather
7.6 cm x 7.6 cm
30 g
Cleaning pad
Intended For
Tablet
Protection
Scratch-resistant
Product Material
PET, faux leather
7.6 cm
7.6 cm
30 g
Brand: Targus
