The new Classic+ laptop case is designed protect 18” widescreen laptops. The new inner sleeve with security strap safeguards the surface and gives additional overall protection to your laptop. The re-enforced handle is wrapped in a soft neoprene to provide comfort and strength. An easy to use functional front zipped organizer will neatly store your mobile phones, pens, business cards, and cables / earphones etc. The case comes with an adjustable comfortable strap when carrying the case on your shoulder.
- Targus Classic+ Clamshell - notebook carrying case
- Product Type
- Notebook carrying case
- Black, red
- Product Material
- Polyester
- 50 cm x 8 cm x 38 cm
- 800 g
- Notebook Compatibility
- 18"
- Notebook Supported Sizes
- 17" - 18" / 43.2 cm - 45.7 cm
- Carrying Strap
- Trolley strap, top carry handle, adjustable shoulder strap, security strap
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 50 cm
- 8 cm
- 38 cm
- 800 g
- 18"
- Notebook Compatibility Dimensions
- 42.4 cm x 29.2 cm x 3.8 cm
- Additional Compartments
- Personal accessories, organizer, front external zipped pocket
- Carrying Strap
- Closure Type
- Zipper
- Black, red
- Limited warranty: - lifetime
